Issue with V1 API Logging in (Error 410 - Gone)
mibrahim01
mibrahim01
I am having trouble logging in to the v1 API via Postman (v7.36.6 latest). I keep getting a 410 - Gone response. The last time I used Postman(over a year ago) it was fine, all the details were saved from my last request. I checked the API guide and everything looks correct. Nothing really has changed (account, user id and password)
Does anyone have any ideas?
philipfrench
FLC V1 authentication is no longer supported.
You have to use V3 (Forge-based) authentication.
After you authenticate you can use both V3 and V1 FLC API calls.
So, the V1 FLC API is still available generally (V3 is preferred).
However, specifically the V1 authentication (/login) API is no longer supported.
In the online help, browse down to REST API v3 Reference --> 2-legged OAuth Tutorial
(Ignore the 3-leggged. It is the 2-legged you will need).
mibrahim01
