Import to Revision controlled workspace - Bad Date
oussama.elaamouchi
oussama.elaamouchi
Hello everyone,
I have an issue with importing data into a revision-controlled workspace. I have selected the properties as follows:
"Version Number" == "Lifecycle Properties -> Revision"
"Version Timestamp" == "Lifecycle Properties -> Release Date"
"Lifecycle" == "Lifecycle Properties -> Lifecycle State"
I am receiving an error message "Bad date" due to the "Version Timestamp". How can I bypass or resolve this issue?
In the Image attached below you can see the error.
PLM-Sylvain.Bailly
In the import screen, did you try to edit the date in red and see if there is no extra space before or after? or delete all what you have inside the field and write it manually (valid with the "Enter" keyboard)
