What I'm trying to do is to send out an formatted email upon a workflow transition that has a hyperlink in it. My script to send the email is calling an Advanced Print View (APV) that I've created that is a email template that I call from the script. The script calling the APV works fine. What doesn't work is the hyperlink within the APV.
The hyperlink I want to display is the URL to a PLM record in the email, thus the dmsID of the record must be a variable and inserted into the href string. This is where the problems begin... Now in my records I store the dmsID in a field for each record. In my APV html code I try and call that field and retrieve its value, but once I enter the code into the editor and press the update button it reformats and removes a portion of the code and when i try to run it it errors with the mystery man.
Below are a few screen shots of my code...this shows what I started with and what I thought would work...
This image shows the reformatting i get when saving the #3 set of code above...
The next two images show #1 above and #2 above the results...
Now the above result is what I want, but remember this using using code that hardcodes the dmsid value and this value needs to be a variable.
Is this possible? If so, how might I go about doing this?
I hope this all makes sense.
Thank you,
John
Solved by tony.mandatori. Go to Solution.
I think you are trying to generate the link in the Advanced Preview...
Instead, try adding the link after loading the APV.
var plmtenant = "https://mytenant.autodeskplm360.net";
var tenant = plmtenant+"/workspace#workspaceid="+wsId+"&dmsid="+itemDmsid+"&tab=";
var tab = "itemdetails";
email.body = getPrintView(avp);
email.body += '<br><br><a href="'+tenant+tab+'">View Items details for '+subject+'</a></br></br>';
Does that work?
Tony
Yes Tony, that does work! Thank you!
However, aesthetically its a bit ugly (I know I can format the text). I really want to know if the hyperlink can be done like this within the APV template that I'm calling? Is it possible? See image below...
Thanks again!
JD
