Get classification fields
Message 1 of 10
We are trying to get a list of all item fields. We use api/v3/workspaces/57/fields however we are not able to get the fields at classification section (in the UI the fields are changed based on the selected classification).
Could you please assist?
Replies (9)
Message 2 of 10
giliar.defriesperez
Hi @Anonymous ,
This is being worked on, and I will have more news to share on it in the future. Please stay tuned.
Giliar de Fries Perez
Sr. Product Owner
Fusion 360® Manage
Autodesk Canada Co.
Message 3 of 10
Thank you for the update. Do you know what are the expected timelines for this development?
Is there a workaround we can use in the meanwhile to access those fields?
Message 4 of 10
giliar.defriesperez
Hi @Anonymous ,
No timeline yet, but it will happen in this quarter. Stay tuned for the release notes. The only other way is to use existing v2 endpoints - you can see what's being used if you use Modern UI and look at the traffic in the Network Panel. It's not officially documented because, as I stated, we are moving it to v3 to then document it in our Help files.
Sr. Product Owner
Fusion 360® Manage
Autodesk Canada Co.
Message 5 of 10
david.therien
Hi Giliar.  Do you have an update on the fix of this issue?
We have an urgent need to edit classification fields, but no longer can.  Checking the box next to a field name used to open an 'Actions' drop-down, but now nothing happens.  Can't delete individual fields either.
Anybody have a workaround?
Thanks!
DT
Message 6 of 10
david.therien
Following up here... I just discovered that clicking the mouse pointer anywhere on a field's row, NOT on the checkbox, will tic the box and allow editing of the field.  Glitchy FLC fun!
Message 7 of 10
giliar.defriesperez
Hi @david.therien ,
I'll report it to the team. In the meantime, also relevant to @Anonymous , the Classification fields are available in the v3 API as part of the item details payload.
Giliar
Sr. Product Owner
Fusion 360® Manage
Autodesk Canada Co.
Message 8 of 10
giliar.defriesperez
Hi @david.therien ,
I followed up with the team. Issue acknowledged, we'll look into revamping the component in the near future and take care of this problem as part of it.
Thanks for reporting it!
Giliar
Sr. Product Owner
Fusion 360® Manage
Autodesk Canada Co.
Message 9 of 10
ian.slater
@giliar.defriesperez
Back in 2020 you said this would be developed in the near future. could we please have an update?
Message 10 of 10
abdulkf
Hi @ian.slater ,
The first issue reported in this post is resolved. Classification fields are available in the response of V3 API api/v3/workspaces/id/fields.
The second issue has not been fixed yet since there is a simple work around (clicking on the row instead of the checkbox) to select the Classification fields for editing.
Firoz
Firoz Abdul Kareem
Sr. Product Owner- Fusion 360 Manage
Autodesk Canada Co.
