Fusion 360 Manage - Part Number Assignment Hangs on Certain Components
chris.stobart
Message 1 of 55
chris.stobart
I've been using the manage extension and successfully assigned part numbers to several assemblies and components. However, I noticed some parts and assemblies were not successful after the initial assignment of part numbers. When I try to assign part numbers specifically to these components the system simply hangs on the part number assignment "checklist". All the components are in the same team and project. Is this a known issue and can I work around it?
C
Replies (54)
Message 21 of 55
chris.stobart
@pierre-yves.monarque
Ok, after some experimenting I found one thing that seems to be common between several of the broken parts. There is a plugin called Bommer that added a revision to the part with the comment "Edited attributes [Bommer]" somewhere in the part's history. Maybe this is caused by the third party plugin?
Message 22 of 55
chris.stobart
I suspect this won’t get resolved by Friday. So, I’ll put one last option on the table which is to have you guys remove the manage plugin and its associated data from all parts and drawings on this team. Then I can reactivate the manage plugin and start the part numbers from scratch as I haven’t used anything in the manage plugin so far.
My preference is to keep the fusion team comments, part history, and design intact over using the manage plugin. However, fusion teams doesn't allow my team to view drawings anymore so I'm at crossroad with this whole thing. The time commitment I've put into this so far and pending deadlines are the only thing keeping me tied to Autodesk software. We can take this to the end of the week and then I'll have to find another way to get untangled from this system.
Message 23 of 55
Hi @chris.stobart
We did another run to heal your design based on latest informations that were gathered.
Can you give it another try, first to see if designs can be released and second if drawings are still not showing in Fusion Team, would it be possible to save new versions of these?
Pierre-Yves Monarque
Autodesk Fusion 360 Team
Message 24 of 55
chris.stobart
I saved new versions of the some of the problematic drawings and the issue in fusion teams is still around. The designs still can't be released either. However, a couple of the problematic components are no longer hanging when you go to release them individually which is a going in the right direction.
Message 25 of 55
pawel.potyrala
Hi @chris.stobart,
Thank you once again for your great patience and your collaboration. Our developers actively work to fix the affected files. We will keep you updated on the progress within the support case.
Thank you once again for reporting the issue and for your cooperation.
Best regards,
Paweł Potyrała
Technical Support Manager
Global Product Support
My Screencasts | Fusion 360 Webinars
Message 26 of 55
anil1973
I am also having the same issue. Does anyone know the solution to this problem? Many thanks for your help
Message 27 of 55
James.Youmatz
Autodesk Support
Autodesk Support
Hi @anil1973 ,
Sorry for the delay. Are you still experiencing the issue? If so, can you please contact our Technical Support teams so that they can begin to triage.
To do this, you can either start a chat with one of our agents, by clicking the Chat icon in the lower-right hand corner of Fusion 360.
You can also email or schedule a call with one of our technical support specialists by:
  1. Visiting https://knowledge.autodesk.com/contact-support
  2. Select Post Purchase Support
  3. Select Help Using My Product
  4. Fill out the details.
Let me know if you have any questions or need anything!
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 28 of 55
scottmoyse
This is happening to me as well. I've raised a case...
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 29 of 55
anil1973
Hi James
I have raised this issue with your technical support teams at least three times. I am still having a major issue with item number assigning. Some parts you just can't assign item number. You have to resave the part then an item number is assigned. Resaving a part as new part resolves the item number  issue but now i have to replace the old part in all the assemblies.
I have also noticed sometime parts and assemblies which has been assigned item number and once were working fine, stops working, i.e the managed extension properties data panel stops showing the data and you get warning sign with a note preparing data>>>>.
I am happy to go through my workflow, please can a tech support reach out to me. I have been struggling with this issue for months.
many thanks
Anil
Message 30 of 55
fredrik.lotto
We also have this issue where it's not possible to assign part number to parts, assemblies or drawings. It happens to ~10% of our files, but haven't seen a red thread...
The sad thing is that it is jeopardizing our future release for a major customer project. Hope for a solution soon, or a fix.
Message 31 of 55
James.Youmatz
Autodesk Support
Autodesk Support
@fredrik.lotto Sorry to hear that 😞 Do you have a support case opened yet? We'd love to get you up and operational.
If not, can you start one either by:
  • Starting a live-chat with a Support Agent in Fusion 360. To do this, in the lower-right corner of Fusion 360 there is an icon where you can initiate a chat,
  • Or by visiting https://knowledge.autodesk.com/contact-support
    • Select Post-Purchase Support
    • Help Using My Product
    • Select Fusion 360 as the product and describe the issue.
Let me know if you need any assistance with this.
James Youmatz
Message 32 of 55
chris.stobart
My Manage plugin has once again stopped working completely and with the original issues that I experienced when I started this thread. Incredibly frustrating as I just renewed the license on a tool that no longer works on any of my parts or assemblies.
Chris
Message 33 of 55
Hi Chris
Can you try to clear cache:
Message 34 of 55
chris.stobart
Thanks, this worked.
Message 35 of 55
fredrik.lotto
Tried the clear cache, but still have the issue.
Also tried the Save-as workaround without successful result.
Fredrik
Message 36 of 55
@fredrik.lotto
We still have a case in progress for issues you are experiencing.
Developers are investigating
I will keep you posted.
Sorry again for faced inconvenience
Regards
Message 37 of 55
@fredrik.lotto @anil1973
A fix has been delivered for managed extension issues you experienced.
Could you let know if it now all works as expected?
Message 38 of 55
fredrik.lotto
@pierre-yves.monarque I'm afraid that the issue remains for some assemblies.
Hope to see a fix soon.
Best regards,
Fredrik
Message 39 of 55
anil1973
I have listed below some of the key issues I am facing.
  • Drawings are taking 2 mins to open. I have 300 drawings to update to the latest model, review and save. That will involve nearly 10 hours of waiting time !!
  • After updating the drawing, If you open the same drawing again, DWG number is missing from the drawing.
  • When you try to quick release the drawing to pre-production, it takes a further 2 to 3 mins, if you are lucky, or in most cases, you get the error below, which prevents you from changing the model state.
My Observations.
  • Connection between Fusion 360 and managed extension is hit and miss. When the connection is not established, managed extension properties are not populated, but the drawings open instantly.
  • After any changes to drawings or models, the managed extension database takes ages to update. So, if you open the drawing straight after a change, either the model number or dwg number is missing from the drawing.
  • If you leave the managed extension to update, sometimes overnight, when you reopen the drawing after a day, all the managed extension properties will display.
  • This intermittent connection between the fusion and managed extension and the slow update of the managed extension database makes it impossible for an engineer to update a design and produce the latest drawings within minutes.
  • Based on the above connection issues, the parts number and drawing number are constantly missing from the BOM.
Based on my ongoing sage with Fusion 360 and managed extension for the last 12 months, I feel bitterly disappointed that these issues have not been sorted out.
@pierre-yves.monarque @James.Youmatz
Message 40 of 55
chris.stobart
It is once again that time of year where I try to generate a release for production and am faced with seemingly insurmountable problems with the manage extension. Below is an image of a table that has blanked out manage data in a parts list. The parts that do and don't suffer from this problem have all gone through the same change order for release into production.
I suspect the problem is related to name changes of components causing desynchronization between the manage plugin and fusion 360. If I click on assign under the manage tab when in one of the problematic components, then I can see the part number, and the previous part name show up. I was able to prove this by renaming all of my components with a 1 in front of the name, reverting them to the original name, generating a release once more, and repeating what I did. Low and behold a 1 appeared in front of the of the problematic part names in the assign dialog and the problem with the manage data persists.
I'm utterly defeated by this plugin and its time to throw in the towel.
