Derived field limitation
sten
sten
I am trying to make a derived field where the derived value is a multi-select list.
However, when I try it does not show up in the list of fields.
Is that a know limitation, or am I doing something wrong.
Sten
nguyentru
Hi Sten,
Currently our Derived Field doesn't allow user to derive multi-select fields.
The Derived Field depends and a Single Select Picklist - Linking to use as a reference point to another workspace (A).
The Derived Field itself acts as a Pivot to pull in information from the field in workspace (A)
You can also read more about Derived Fields - http://help.autodesk.com/view/PLM/ENU/?guid=GUID-811A28B2-E80F-4794-AE2E-22DC2F0C430F
thanks,
Trung
Trung Nguyen | PLM Product Management | Autodesk, Inc.
sten
Ok. I made a script workaround that just copies the 'derived' multi-select to the local multi-select.
