Conditional statements in advanced print view
bryce_crawford
bryce_crawford
I would like to build a print view that displays BOM lines only if one of the fields meets a certain criteria. I haven't been able to find a way to do this. Is this possible? If so, how would I go about setting it up?
philipfrench
@bryce_crawford
Not as far as I know. I think this would need scripting, which is not supported in APV.
You might be able to generate some HTML table as text into a RO paragraph field (scripting in OE), including the only rows that you want. Then you could bring the whole HTML into the APV ?
(As ever, the problem would be the trigger point for such a script is on Item Details, not on the BOM tab.)
