I'm pretty new to Fusion Lifecycle but have created several classifications through the classification mananger.
I'd like to build a custom report using values from the fields in the classification. E.g Screw length, colour of cable etc.
The section for classification is greyed out, I presume because Fusion Lifecycle isn't going to pull all the custom fields (which I suppose could be limitless), but I can't see another way to get the value. Are only static fields allowed to be used in reports?
Is there a workaround for this?
Any help would be much appreciated.
Solved by gasevsm. Go to Solution.
