Changing Owner of workspace not recognizing lastName in Security.searchUser
trentearley
trentearley
Hello, I am running this script to change the owner of the workspace to the CSR.
var username = item.CSR;
var nameArray = username.split(",");
var lName = nameArray[0];
var fName = nameArray[1];
var userINFO = Security.searchUsers({lastName:lName, firstName:fName});
item.master.owner = Security.loadUser(userINFO[0].id);
I am getting an error saying "cannot get "id" from undefined".
But when I remove the firstName:fName from the Security.searchUser command it works.
So my question is, Why is the firstName not being recognized by the searchUser command?
Trent
jmarsh76
I think it's a simple syntax error.  For the line var nameArray=userName.split(", "); you need a blank space after the comma.
nguyentru
Hi Trent,
Try using this script.
var userName = item.CONTENT_DEVELOPER_1[0];
println(userName);
if(userName !==null){
var nameArray = userName.split(", ");
var LName = nameArray[0];
var FName = nameArray[1];
var users = Security.searchUsers({lastName:LName, firstName:FName});
item.master.owner = users[0];
You also find out more information from one of our Developer - http://justonesandzeros.typepad.com/blog/
I hope this help.
thanks,
Trung
Trung Nguyen | PLM Product Management | Autodesk, Inc.
trentearley
Thank you! I figured I was missing something obvious.
