I`m looking for a solution to change revision number via API or script.
I`ve used this solution Solved: Set Lifecycle State and Revision via API - Autodesk Community - Fusion Manage
but this creates a new revision. Is it possible to update the version number without creating a new revision?
I've entered a revision number with an error and i should to change it withaout generating additional informations.
Example: from 1.0 to 1.0A
The revision number is limited to 3 characters. Can this be changed and set to any length?
When I`ve tried to send revision with 5 characters.
