Are the Classification Manager fields searchable in MOdern UI?
I don't know if I am doing something wrong, but I am searching for a value on a field on the Classification Manager, but it is not rendering any results. Is the search not connected to the fields from the Classification Manager?
Thanks!
cgong
Unfortunately you're not doing anything wrong. It doesn't appear that Classification Manager Fields are accessible via search.
To get around this, we actually push Classification Manager Field data (via an on-edit script) to fields within Item Details (which as you know are searchable).
Thanks for the prompt response and the suggestion! I would like to try that as well.
Do you have any performance issues on Edit or Save?
Thanks!
cgong
You shouldn't see any performance issues with adding this functionality to your on-edit script. But of course, as you add more and more; expect some sort of performance degradation. Nothing too major though.
eric.mcsherry
Here is a script that I have used to work around this issue.  It creates a comma separated list of classification field names and values in the pattern:
PREFIX:035, TOLERANCE:2, PACKAGE:0402, HEIGHT:1, MOUNTING_STYLE:SMT, VOLTAGE_RATING:50, CAPACITANCE:100.
It will work on any classification structure.  You'll just need to create an item details field of type single line text.  In the example below, I've named the field "Classification Values"
With this string you can search on one or more classification attributes.  For example, you can search:  PACKAGE:0402 and the search will return all 0402 components.
script
function objToString (obj) {
var str = '';
for (var p in obj) {
if (obj.hasOwnProperty(p)) {
if (typeof obj[p] === 'object'){
str += p + ':' + obj[p].displayValue + ', ';
}else{
str += p + ':' + obj[p] + ', ';
return str;
var classString = objToString(item.classification);
item.CLASSIFICATION_VALUES = classString;
michelle.stone
Eric beat me to it!  I'd written up an article for his method previously: https://knowledge.autodesk.com/support/fusion-lifecycle/troubleshooting/caas/simplecontent/content/s...
Michelle
Michelle Stone
Technical Marketing, PDM & PLM
I remember when classification manager first came out, it wasn't searchable and for years I did not use it because of this.  I recently came back to it and just gave into extracting the json string and populating item fields to make it searchable.  I used a colon separated string.
