I have a Document WS, and would like to create relationships across documents (this is a Revision Controlled WS). However, I've noticed that the Relationships I add on a specific version, don't carry forward to the system generated Working Version. Is this expected functionality?
How can this be automated?
Thanks!
That's not what I see in the classic UI.
For me, the relationships carry forward and the icon changes to reflect that it was carried forward.
This is how the old version looks:
This is how the new version looks:
You can recreate these relationships through script by:
Wendy,
The intention is definitely to carry the relationships to the new revision (and the working). If this is not what you are seeing, I recommend to open a bug report on it.
Thanks! I will test this again.
Another question though, how are relationships maintained with revisioning WS?
Example:
- Document A: Rev 1 is related to Document X: Rev 3 and Document Y: Rev 4
Use Case:
- I want to make sure that when Document X is revised and becomes Rev 4, it will still be related to Document A.
Question:
- Do I need to associate it to the Working Revision instead of the Released versions?
Thanks!
I think you're OK.
When Document X is revised to Rev 4, it will still be related to Document A Rev 1 - but the icon will be blue to indicate that the relationhip was carried forward from revision 3..
If you want to keep them in rev synch such that both revise together, then you will need to attach the new version (either manually or via script). For example some people want both X and A to revise together. FLC doesn't attempt to keep revisions in synch.
Hi Martin,
I will test this more, but what I am looking for is for the relationship between Documents to be maintained, regardless of their versions. This means that:
Document A: Rev 1, which is related to Document X: Rev 3; will always be related to Document X automatically. So, when Document X becomes Rev 4, Rev 5, etc; this relationship will just be updated, not static on a version at a particular point in time.
Does the system do that?
Thanks!
Thanks Martin!
To clarify, when I mentioned Documents, I meant Document Items (your assumption was correct).
I will test the approach with the BOMs. However, for documents, there is no effectivity date, once a document is Published, it becomes Effective. Do you see any issues with this approach?
Note: the picklist approach would not work because it has to be a-way relationship, and there is a 1:many relationship between the Document Item and the related Document Items.
Thanks!
There is no issue with that Wendy.
In fact, Fusion Lifecycle always has effectivity for all revision controlled items. By default the effectivity is the release date. So as long as you use the default configuration of the BOM (using 'today' as the date) then you'll get the latest related document.
Thanks!
I am confused though in my testing. When I test this the relationship is only one way, cannot figure out how to make it 2 way. Any ideas on why this may be?
Thanks!
Hi Martin, I tested the BOM approach and looks promising! However, I cannot get the relationship to be a 2 way relationship. Is there a way to make it a 2 way relationship?
Hi Martin, so to clarify, this means that until we don't have access to the Where Used section in Modern UI, the user will not be able to see the 2 way relationship. Thus, at this point, we can create the Relationship, but we cannot see the 2 way association. Correct?
Thanks!
Wendy,
Relationships that are managed in the 'Relationship tab' show up on the relationship tab of the related item. Those are available today and you should be able to see them. A user will need to have access to the relationship tab of the related item in order to see the relationship so if you are not seeing the tab, you will need to add the permission to it. The 'Where Used' tab is unrelated to this and shows the relationship to parents that are managed in their BOM tab.
Hi Hagay,
Relationships don't work for us because the relationship does not respect the new versions. For example, if I associate Document A Rev 1, to Document B Rev 1, when Document B moves to Rev 2, this relationship is not updated. Per the explanation Martin provided, this is because the Relationship is at the DMSID level. Thus, we are looking to use BOM to handle the relationships across Documents. However, the problem we face now with it, is that this is not showing the 2 way relationship (but it respected the revisioning). From my understanding the 'Where Used' tab would give us this visibility. Is that the case?
