Hi guys,
I have a field where I want to make required when another field "is not null". Is there a simple "is not null" condition I can put here. See below image. Thanks.
Could you consider doing the validation check on a workflow transition? (in a validation script).
I could in a validation script of the item. I thought maybe it could be done without scripting.
[http://www.nucap.com/images/image001.jpg] Jason Leung - Design Engineer
NUCAP Industries Inc.
3370 Pharmacy Avenue, Toronto ON
Ph.416 494 1444 FAX.416 494 2505
Jason.Leung@nucap.com
Please visit us at www.nucap.com www.gripmetal.com
[http://www.nucap.com/images/banner-brakealign.png]
Try using the 'If One Than Other' validator instead.
Tested it out and should work for you - set up the If One Than Other on a field and if I fill in a value there but not the other I get the warning.
Pictures or it didn't happen!
What's the field type for your Tracking# field? I see the 'If One than Other' for the single line text field type:
Both or None could also work - I put that validator on my Facility4 integer field (against Product Line) and if I fill out Facility4 and not Product Line I get a message:
