Upload DWFx and colors change
mikeh4
mikeh4
Uploaded a DWFx yesterday to Fusion and the colors of the components change between the actual DWFx on my hard drive that I exported from Inventor and what shows up in the Fusion viewer online.
Initially I exported from Inventor using the complete setting, and only picked the View Rep I wanted.  On the Hard Drive it showed up as expected.  Drag into Fusion project and it gave  me the master view rep, with all components.
So went back  to Inventor and Exported the DWFx using the express mode and the current View Rep is used.  Again the DWFx on the hard drive looks correct.  Drag it into the Fusion project and it gave me the correct visibility of the components, but gave me the wrong colors on those components.
Has anyone else experienced this issue.  I can't post the files to the forum because they're a sensitive conceptualization.
Thanks!
masa.minohara
Hi Mike,
Thank you for posting about the issue! I just sent you an email regarding this. Could you reply to me with the file and some screenshots of the issue?
I look forward to hearing from you.
Thanks!
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
mikeh4
Has there been a case number applied to this issue.
Thank you!
Okay, fine thanks for informing.
steveh3
Appears team is still working on this...
Mike and I are same company and same issue...
Providing screen captures of viewing models in Inventor, ADR, and Fusion Team....problem appears to be in Fusion Team and not the dwf that we uploaded.
Steve Hilvers
Inventor Certified User / Vault Professional Influencer
