Extrude falls outside boundary
elliotGDUHS
Observer Observer
elliotGDUHS
Observer
Observer
Hi - from another annoying newbie,
I've seen this heading several times in the forum when I search but I cannot see an answer to my problem. I am creating a fan with a gusset on the back of the impeller blade. I want to extrude the gusset to the centre hub, but this is into a tapered & curved area.
Is it possible to select multiple faces to extrude/pull to? Or is there another method I can use to create the shape?
I have attached the fusion file and this is a screen shot and any help is appreciated.
Elliot
Marco.Takx
Hi @elliotGDUHS,
Is this what you are after?
See the steps I used in the timeline.
I deleted your offset and used 2 Split Bodies to split the Blade into 3 bodies.
After that, I removed the 2 bodies that were not necessary.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
elliotGDUHS
Observer
Observer
That is absolutely perfect, thank you. I'm going to try and do it myself now I know it can be done, to make sure I understand.
Thanks again 👍
