Data panel search bar returns with error message on my Fusion 360 Team Hub after transferring a project from my Personal Hub.
cem.yavuz
cem.yavuz
I've moved a project from my personal hub to my Fusion Team Hub. There were more than 1000 part files and more than 100 folders and subfolders. Now, on desktop Fusion or even on web browser Fusion it doesn't matter, in my Fusion team hub I can't find my files when I search with keywords on data panel search bar or on browser Fusion search bar. Desktop Fusion shows an error message: "There is no object with ID Community [############] present." There was no problem like this when the same project was on my personal hub, I could have found any of my files by searching on data panel. Now, it's a huge waste of time to search manually a part file on each folder. Is there any solution or a future update to solve this problem on team hub?
robert.filiks
Hi @cem.yavuz,
thank you for posting,
As a workaround to you can try to move the folders/files affected to another project within your team hub, so the re-index should be triggered again. The re-index could take some hours but as a short-term fix, it should work.  If there are 5 different projects, create 5 New projects and move files correspondingly.
Robert Filiks
Software QA Engineer
My screencasts | Advanced Manufacturing | Tips and Best Practices
cem.yavuz
Hi Robert,
Yesterday about 15 hours ago I've moved the folders/files affected to another project within my team hub under another Autodesk support agent's guidance. At that moment, the problem was still existing but now I checked again and problem is solved. I can make search on Team Hub Data Panel or on web browser Fusion Data Panel and I can see correct results related the keywords. I guees it needed some hours to re-index the folders and part names. Thanks for your support.
