Combined Projects
Combined Projects
Combined Projects
Is there anyway to combine projects or merge projects?  I initially created different projects, but I am now having issues with using files between projects.  Ideally, I would have a master folder (project) that would then have sub-folders to organize the files.  I basically, would like to take take a few of my current projects and place them into one project folder with each of the current projects becoming a sub-folder in the master project.
Thanks in advance for any help you can provide.
asiteur
Hi there,
By now you should be able to reference files in other projects, what kind of issues are you having?
To answer your question: you cannot move projects into eachother. But you can move the files inside the project into another project.
Just open your project, select all files with the checkbox on top and use the move icon that appears (also on the very top of the file list).
Now select your destination project and folder.
Hope that helps!
Alexander Siteur
Project Engineer at MARIN | NL
LinkedIn
