@margot_caumont wrote:
I tried your file, and it works well.
I didn't find in Inkscape how to degroup my picture and delete the double outline. Can you give me the way to go please ?
Having now worked on your file I found that nothing was grouped so there was no need to ungroup it. The entire design is a single 'path' so I first needed to break it apart:
Once you've broken it apart you can delete the paths you don't need. You might find other functions such as 'Inset' and 'Outset' useful too if you want to adjust the remaining paths inward or outward.
I'm not clear whether your second file is a screenshot of a vector file or the PNG you posted is the file. If it isn't vector already you'll either need to obtain a vector version or trace it in Inkscape (or another application you have access to). Fusion will not be able to use a raster format file for extruding. I'm also not quite clear on your other statement about deleting parts and different levels etc.
I hope this helps.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
