I'm receiving a text-to-pad error for every castellated pad on the board.
Each pad is composed of a round pad and an offset pad.
The net and pad names, visible on the board, are not on the SilkscreenTop layer.
How can I remove this error?
Please find attached the pictures showing the error and the footprint.
Thanks.
Regards
Solved by jorge_garcia. Go to Solution.
Hello @FrankEagle,
I think this is a red-herring. The error is more than likely caused because you have part of the pad outside of the board boundary. With castellated boards this is inevitable so you can just approve the error.
I will report this to our developers so that they can have a look. Let me know if there's anything else I can do for you.
Best Regards,
