Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Text negative
6 REPLIES 6
silvio3105
420 Views, 6 Replies
Text negative
Is there any way to create negative of text? DXF import is out since text is variable.
6 REPLIES 6
Hello @silvio3105 ,
I'm not sure if this is the right solution to your problem:
  • add text to layer 41 (tRestrict) or 42 (bRestrict) and use "vector" font:
  • do a "ratsnest"
Eagle 9.6.2 / Fusion 360
Working with Eagle since Version 3.x
No, I want negativ text in silkscreen
Hello @silvio3105 ,
then you have just do that in the corresponding layer.
Are you really sure to to that in silkscreen (Layer 21/22, tPlace/bPlace)?
Or do you want it in layer 29/30 (tStop/bStop)? So there is no solder stop where the text is.
Hi all,
have you found a solution for negative text on SilkScreen layer? E.g. like in Arduino board?
It can be done with a ULP, not that easy.
For a tutorial: https://atadiat.com/en/e-negative-silkscreen-eagle-ulp/
Note that you use the ULP for fusion.
Just tested it myself and it works.
Thanks. Is it a set of lines, as I can see? Is there another option to have a polygon on the silkscreen layer? I mean, the lines can't be scaled after creation.
