is there any way to set library description? I cannot find any button for that in library or data panel.
Solved by yiqiu.han. Go to Solution.
There are two types of description: One is the EAGLE way: you can just type "description" in the command line to add it. The other is the Fusion cloud description which can be added when you save your document.
Hi, @silvio3105
I guess your desired way is EAGLE description, type "description" in the command line to add it is feasible in both EAGLE and Fusion 360, saving is not necessary here on both platforms.
Fusion cloud description is only available for Fusion.
Yiqiu
Hi, @silvio3105
Yiqiu
