Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Rigid-Flex design how to place parts on internal layers
4 REPLIES 4
christopher2KLSVU
318 Views, 4 Replies
christopher2KLSVU
I know f360 does not support rigid-flex yet, also there are just few threads on forum where people connecting two normal PCBs with flex inter-connector.
The 'whole' work around is to just use internal middle layers as flex layers and just inform the pcb manufacter to treat it as flex. Routing of tracks and vias are done as usually.
But how do I place components lets say LED (smd0805) on a internal layers?
Usually when we place parts they jump on TOP and when we want to move them to the Bottom layer we make part mirror.
Let say I defined  4layers stack:
L1 Top (FR4),
L2 Flex top
L3 flex Bot
L4 Bottom (FR4)
How to place parts on internal layers L2 or L3?
Theoretically in worst case I could make it as two separate designs with same board outlines and proper manual parts placing. One design would be a 2 layers for fr4 and second separate design for flex layers, then producing gerbers combining them together and send them to pcb manufacture.  But thats to much manual work. I hope there is much clever solution.
@jorge_garcia
@yqliu
@RichardHammerl
L1 Top (FR4),
L2 Flex top
L3 flex Bot
L4 Bottom (FR4)
@jorge_garcia
@yqliu
@RichardHammerl
Tags (1)
Labels (1)
4 REPLIES 4
yqliu
in reply to: christopher2KLSVU
yqliu
Hi @christopher2KLSVU , neither rigid-flex nor internal layers is supported and I'm afraid there is no good solution now. We will let our product manager @melisa.kaner know this requirement and prioritize it.
christopher2KLSVU
in reply to: yqliu
christopher2KLSVU
Please just make small hack to unlock possibility to place the parts on inner layers. Or temporarily allow user to modify the layers stack so that the inner layers become top or bottom then user could place parts, route tracks and when job is done back to normal layer stack.
yqliu
yqliu
If you just want to create a 3D representation and won't push back to 2D,  a workaround you might try is to insert the 3D PCB into a normal design and break link, then you can make changes to the board using the modeling tools.
melisa.kaner
As @yqliu mentioned unfortunately we don't natively support rigid-flex yet. However this topic is top of mind for us. I'd love to jump on a quick call to discuss your requirements for this. If this sounds good to you, please send me a DM and we can find some time to chat.
Best regards,
Melisa
Melisa Kaner
Product Manager - Fusion Electronics. Please DM me for Fusion Electronics feedback!
Best regards,
Melisa
Melisa Kaner
