Representing internally connected device pins
josh_l
josh_l
I have created a Fusion 360 electronics library device that represents a small prototyping board that will be mounted onto my PCB via header pins as a "sub-board" kind of arrangement.
The sub-board has multiple GND pins. I would like to be able to connect any of my traces to the nearest GND pin and have F360 know that they're the same thing. Is there a way to achieve this by altering the design in my Library device? At the moment I get a bunch of unnecessary airwires because the PCB editor doesn't know that the multiple GND pins on the sub-board are internally connected, even though there is a path path to GND connected everywhere there needs to be.
I'm aware I can just hit Approve on the DRC errors - I'm just looking for a better solution.
Thanks in advance for your help!
Josh
jorge_garcia
Hi @josh_l,
I hope you're doing well. This is something you can correct in the library. Open the Device for this component and click on the Connect button on the bottom right.
Make sure that you have all of your ground pads connected to the same pin in the symbol. If you have a 1:1 pin to pad relationship this won't work so it's recommended that you assign all of the gnd pads to the same pin. Make whatever adjustments you need to make to the symbol for this to work.
When you do this you'll see a little icon show up next to the connections, to the left. If you hover over it, it will say either all or any. Left click it to change it.
In your particular case you wan Any, that means that as long as any of them are connected the netlist will be satisfied and you won't get the extra airwires.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
josh_l
Thanks Jorge! I'll change my symbol to only have one ground pin - I think that's where I was going wrong. I just made a symbol that represented all of the physical pins, but I see now that there was no point modelling the extra ground pins in the symbol when that's more of a detail of the physical part than the schematic.
Cheers!
roatchristopher
Is the use of swap-level on the pins ever useful in this context?
jorge_garcia
Hi @roatchristopher,
It would be hard to find a use from swap-level in this context because you are consolidating all the ground connections onto a single pin. So swap level would imply that there is some other gnd equivalent pin that we could swap with, but that's not possible in this case because all the gnd pads have been consolidated into 1 pin.
Best Regards,
Jorge Garcia
roatchristopher
I like the idea of connecting the ground pads to a single pin, as then the schematic makes sense semantically.
But, if the pins were not tied together, would it work to use swaplevel instead?
jorge_garcia
I hope you're doing well. If they were not on a single pin, then you would go the old school way. One pin for each pad, swaplevel the same non-zero value for all of them and you would name them GND, GND@1, GND@2, GND@3, etc.
The @x syntax is important, it allows each pin to have a unique name as required but when used in the schematic the @x is dropped so you see all the pins named GND.
Best Regards,
Jorge Garcia
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
