Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Rename signal layers?
2 REPLIES 2
infinitemach
299 Views, 2 Replies
Is there a reason why I can't rename the signal layers.  I'm creating a 4 layer board and I want to name the signal layers 2 and 15 appropriately. Why can I change their names from Route2 and Route15?
2 REPLIES 2
panpan_fan
in reply to: infinitemach
Hi @infinitemach
I hope you are doing well!
I have a quick try and I can rename signal layer name successfully.
Would you mind trying again in the Display Layer panel?
Panpan Fan
infinitemach
Thank you, yes that works. I was expecting to be able to edit the names when setting up the board stackup.
Technology Administrators
