I have a schematic and trying to see where the component is on my PCB design.
When I click on "SHOW" and on the symbol in the schematic, it sometimes doesn't highlight the component on the PCB. (BTW not easy to see it even if it is highlighted, I think an improvement might be that the component is highlighted, zoomed in and centered in the screen)
But if I click on "SHOW," then switch to PCB and click on the component, the symbol/component is highlighted in the schematic.
Is there a setting that I am not aware of?
Thank you!
Solved by m.s.uludag. Go to Solution.
Solved by panpan_fan. Go to Solution.
Hi @m.s.uludag
I hope you are doing well!
For the highlighted request, we have the Cross Selection feature now.
You do nothing but just click to select one component in schematic, then you can switch tab to 2d PCB. You will see the component will be highlighted in 2d PCB automatically.
Please have a try to see if it works for you.
Panpan Fan
