"Error: Could not create temporary directory for CAM export" On every windows PC I try
gregF29ZL
gregF29ZL
I'm trying to export Gerber files and I continually get the error "Error: Could not create temporary directory for CAM export" or some related error stating that the 'temp' files could not be created or are missing.
I'm tried multiple PCs, on different networks, all running the latest version. I tried re-installing Fusion multiple times. No dice.
yqliu
Does the file name contain any special characters? If so, you can try to rename the file and see if it helps.
