Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Modules and ports
2 REPLIES 2
robert.martinUKYP4
673 Views, 2 Replies
Modules and ports
I have been creating a large schematic and have broken it down to modules and where applicable, I would like to have busses between modules. When adding a port, I have the option "Net or bus of module: XYZ" but I cannot see any busses in there, only nets. Have I missed a tickbox somewhere to break out busses in ports?
Labels (1)
2 REPLIES 2
Hi @robert.martinUKYP4 ,
You haven't missed a button, this is actually an incomplete part of the hierarchical workflow. For now only nets break out properly. So you can use a bus at the top level schematic between modules but you'll have to break it out to connect to the modules.
If I've misunderstood what you are referring to(entirely possible) could you post a picture or a little more info that might help me narrow it down.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Hi Jorge, In that case, you should probably remove the word bus from the port command as it is pretty misleading and I wasted a lot of time trying to make it work
Technology Administrators
