Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Modifying the name of a NET in an existing BUS
4 REPLIES 4
mikestebbins08
211 Views, 4 Replies
I am develping a multi-page schematic and have identified several BUS's with over 20 NET's in each BUS. Nearing the end I would like to change the names of the NET's to be more descriptive. Changing the name of the NET doesn't change the name in the BUS however, and I have found no way to go into the properties to change the NET names. When I do I receive the error,    Error: Bus alias already exists.
Is there any way to update names in a BUS without having to redo the entire BUS?
Thanks for your help!
Mike Stebbins
4 REPLIES 4
CGBenner
in reply to: mikestebbins08
@mikestebbins08
Hello Mike, and welcome to the Community.  I've moved your post here for greater visibility with the Electronics design experts.  Good luck!
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
edpataky
Hello there!
I am attaching a video of how I am doing what I believe you are describing .. As you can see i have made a bus from a bunch of signals in the schematic, then changed the NAME of one, selected ALL, and then confirm the change to the bus.  I verify after that all are changed also.  It seems to work but maybe there is a workflow where it does not .. Please let me know if this helps.
mikestebbins08
in reply to: CGBenner
Thank you! I received a solution quickly, I am impressed! Mike Stebbins
mikestebbins08
in reply to: edpataky
Thank you very much for your help, solved the problem and saves me a LOT of time!!! Thank you for taking the time to help me with this, I greatly appreciate it!
Mike Stebbins
Technology Administrators
