Fairly newbie question, but I just can't find the answer. I've set up my PCB the way I like it and shrunk down the size as much as possilble. Unfortunately, I did this away from the origin. I'm not struggling to shrink the board size. If I try and change the 20 Dimension, it CUTS my design out of the board, rather than cutting TO the board. How do I either:
a) move all components, tracks, labels, etc., down towards the origin, or
b) change the origin to the bottom-left of my board and then cut it to size
I just can't find this in any help or tutorial (or at least, cant get the tools to work right), most likely as the tutorials assume you do everything correct! Thanks in advance for any suggestions.
