Is it possible to make the "3d PCB" generated when you press the "Push to 3d PCB" button conform to the layers selected in the manufacturing CAM processor? I want to generate some prototype boards where layer "27 ValuesTop" is on the top silkscreen layer instead of the "25 NamesTop", however ultimately I will generate other boards where "25 NamesTop" will be the used instead.
I was able to do this in the manufacturing CAM processor; however, that selection did not alter the "3d PCB" model.
If there is another preferred method to select/deselect layers that feed the "3d PCB"?
-Wayne
Hi @lidaar532,
I hope you're doing well. Go to the Display Layers panel. On the top right you'll see a gear icon. This takes you to the layer sets manager.
In there, you'll find the layer sets for the top silkscreen and the bottom silkscreen. By adjusting these sets you can control what layers go to the silkscreen on the 3D PCB.
Let me know if you run into any problems.
Best Regards,
