Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How to define an edge connector / gold finger
2 REPLIES 2
FrankEagle
573 Views, 2 Replies
I need to move the attached pad (composed of a ring and a top/bottom pad) on the edge of the PCB, but this is not compatible with the DRs and Fusion doesn't let me do it.
Is there a way to define an edge pad that can bypass the distance rule from the board dimensions?
2 REPLIES 2
jorge_garcia
in reply to: FrankEagle
Hello @FrankEagle,
I hope you're doing well. The easiest thing to do is to disable the copper/dimension check in the DRC. Go to DRC > Distances tab and set the copper/dimension value to be 0.
That should take care of it. Once you have it placed then make sure to set it back to whatever your board house can do.
Best Regards.
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
FrankEagle
Thank you.
Technology Administrators
