Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How to combine Electronics Designs?
12 REPLIES 12
Message 1 of 13
bostonK74CU
1263 Views, 12 Replies
I am having a rough time trying to combine two Schematics/PCB's I have been working on at work. They were going to be separate boards but we have more space than expected and we decided to put it all on the same board, I just need to "copy/paste" them together with some minor edits. Panelizing them is not acceptable as they need traces going from one to another (which were previously terminal blocks and wires.)
Copy/pasting the components from one schematic to another "works," but then I'll have to redo the layout of all those components on the PCB, which is obviously unideal. After some googling, I have tried creating a separate Electronics Design, create a new PCB, copy/paste the layouts from both into it, then link it to a schematic with their schematics on different sheets. This should work, expect I get the error "Schematic/PCB sync deactivated: Run ERC to find differences and resolve them." Clicking on this shows the "ERC Errors" window (attached), and clicking on Synchronizer, then Run, also yields no results, just removes half of the traces.
Any help would be much appreciated. Thanks.
12 REPLIES 12
Message 2 of 13
jesper8W75R
in reply to: bostonK74CU
My guess is that you could use Design Blocks to do this.
I haven't tried this feature, but it might solve your problem.
I think you could make one of the designs a design block, then pop it into the other design.
Message 3 of 13
jorge_garcia
Hi @bostonK74CU ,
I hope you're doing well. In the latest release of Fusion 360 there is a feature called insert Schematic that is related to Designblocks. Make sure both your schematic and board are open and then try this feature to insert one design into the other.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 4 of 13
Hello @bostonK74CU,
as you can see in the ERC-Dialog, al lot of parts are connected to the "wrong" net.
You can solve this by renaming the nets "GND1", "3.3V1" and so on to the desired net-name.
You can do this in schematic or in layout.
Try to identify net "GND1" and change its name to "GND". The next "ERC" schould show less errors.
Some earlier days, the "ERC" generated a text-file, where you found all ERC-errors, so someone would be able to solve the ERC-errors step by step with the text-file.
No fear, if you do this step by step, your problem can be solved in only a few minutes.
I think this way is much easier than generating design blocks.
Eagle 9.6.2 / Fusion 360
Working with Eagle since Version 3.x
Message 5 of 13
@m.neujahr_at_moe
I tried that, and it seems that the ERC is adding the "1" to the end of GND by itself. On both sheets the value for the GNDx symbols read "GND." However, in the ERC dialog box is shows GND for sheet 1 and GND1 for sheet 2. Very odd.
Message 6 of 13
bostonK74CU
in reply to: jesper8W75R
@jesper8W75R@jorge_garcia
Yes, looks like that should work, except do you know how to save Design Blocks? I can see the "Insert Design Block" option on the Schematic and PCB tabs, but no way to create one. Everything I can find says that Design Blocks are not functional in Fusion yet, although most of that is from 2020. A bit frustrating how hard it is to find documentation about this. The Fusion 360 documentation lists the Design Block functionality in the Features, but I can find no info on how to implement it.
Edit: Figured it out! Method is convoluted and poorly documented, but using Design Blocks works. Summary written below.
Message 7 of 13
bostonK74CU
in reply to: jorge_garcia
@jorge_garcia
Tried that. Has the same effect of copy/pasting the components from one schematic to another. Components are transferred to the schematic successfully, but the PCB layout is not.
Message 8 of 13
bostonK74CU
Okay, I figured it out. Design Blocks work (they are functional in Fusion, despite what the forum thread says.) What you do is go to the schematic/PCB (either work) you want to import, write "write dbl" into the command line at the top of the screen. Save-as the design to a place locally (cloud is not an option.) Then go into the schematic you want to insert the original, then Design: Place: Insert Design Block: Select from my computer. Select the .dbl file you saved locally. Place the block of components. The PCB layout will be preserved. Just move them where you'd like, then delete the old border.
Message 9 of 13
peter
Thank you Boston. I have been trying to work out how to create a design block.
I had no idea it was a command line to save.
Message 10 of 13
giladk
This doesn't work (might have working in the past)
You can open the dialog by writing "write dbl" but no files are being actually saved.
Message 11 of 13
jorge_garcia
Hi @giladk,
As reported on the other thread, the recommend solution no is to use the Insert Electronic design command. Both the schematic and layout come in. Please let me know if you are not seeing the layout come in. In order for the layout to come in, there needs to be a 2D PCB open together with the schematic.
Best Regards,
Jorge Garcia
Message 12 of 13
giladk
Hi Jorge.
This works but this is copy-paste.
When I change the original it does not propagate down.
This feature is just half baked, more like 25% baked...
Gilad
Message 13 of 13
jorge_garcia
Hi @giladk,
Designblocks didn't propagate either, so we have parity. I agree that it would be very useful if these circuit blocks could be treated just as components and have them update and propagate changes, but we've never had that. This would be net new functionality. I'll pass your comments along to our team to include that in the sub-circuits work that's being done.
Best Regards,
Jorge Garcia
Technology Administrators
