I used the connector (PINHD-1X5) in the parts library but I would like to modify the PADs to use a circular shaped pad rather than an oblong shaped pad.
What is the easiest way to do this?
I have already created a provisional layout (without routing) with the oblong shaped pad but would like to modify this to a circular pad as the oblong style pad is taking up too much space for what I need.
See attached images.
Hi @Anonymous ,
I hope you're doing well. The best approach would be to copy the part to your personal library and then edit it there to change the pads to be circular.
If you haven't made parts before I recommend checking out this series of videos:
https://www.youtube.com/watch?v=xNIEXCimRSg&t=4s
Let me know if there's anything else I can do for you.
Best Regards,
