Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How to change 3D package orientation?
2 REPLIES 2
dev2EP8UX
174 Views, 2 Replies
A component on a PCB that has been imported from EAGLE should get replaced by a component in a different library (which is identical except the new part has a 3D model). The EAGLE design should retain the same part angle for backwards compatibility of the manufacturing files.
I replace the component from the schematic, but the new component shows up in the 2D PCB at an incorrect angle again. When I go back to the library to adjust the orientation of the 3D model by 90°, this change has no effect in the 2D PCB (orientation of the part is still in the same wrong direction, component used and its angle per 2D properties also is the same as expected, of course all files updated from saved library).
Any hints?
2 REPLIES 2
jorge_garcia
in reply to: dev2EP8UX
Hi @dev2EP8UX,
The issue is likely in the library. You would have to be able to compare the orientation of the 2D footprint in the original library and it's orientation in the new library. If they are different that would explain the difference you are seeing. Make sure that the 3D model is correctly placed in relation to the 2D footprint.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
dev2EP8UX
in reply to: jorge_garcia
Thanks, Jorge, that was it, thank you! Seems very clear now - I got confused...
