I'm trying to center a component along the edge of a PCB, but can't find a way to do it. I've tried the align command by selecting both the part and one of the lines. That didn't work. How is this done?
Edit: I ended up just dividing the width by 2, which might be the only way. Quite simple, but it can be a bit tedious when resizing the PCB a lot. It would be very handy with a button.
Solved by jorge_garcia. Go to Solution.
Hi @pstormarkG9SGY,
I hope you're doing well. Once we get more of Fusion's inferencing into the 2D PCB these types of operations will become easier. Thank you for the feedback.
Let me know if there's anything else I can do for you.
Best Regards,
