Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Fusion won't allow me to edit shortcuts
3 REPLIES 3
AJ5QLT7
250 Views, 3 Replies
I'm trying to create some shortcuts for swapping from top/bottom layers of my PCB. So it's easy to add a shortcut, but what happens when you forget to add a layer -> you try to edit the shortcut with the provided edit button. This button only let's you edit the hotkeys and not the command itself (which is grayed out), which is HIGHLY annoying when trying to add or remove a layer. What's going on here?
Labels (2)
3 REPLIES 3
AJ5QLT7
in reply to: AJ5QLT7
@Anonymous?
panpan_fan
Hi @AJ5QLT7
I hope you are doing well.
For the shortcuts issue, sorry that we don't support editing commands directly with shortcuts dialog.
As a wordaround, you can copy (Press Ctrl+C to do the copy) the commands and create a new shortcut for it.
It may save time for you.
And I will report this issue to the team to see if we can do some improvement for it.
If I get more inforamtion, I will keep you updated.
Panpan Fan
AJ5QLT7
in reply to: panpan_fan
It's extremely peculiar and highly vexing that you cannot edit a shortcut when there's an edit button right next to it. Let's please get this fixed!
