Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Fusion 360 - Electronics Cooling - Temperatures too High
0 REPLIES 0
Message 1 of 1
eschacht
125 Views, 0 Replies
I am currently designing a battery charger made of sheet metal. Inside the battery charger, there is a module called an inverter which is generating 1.5 kW of heat.
To model this in electronics cooling, I have simplified the enclosure geometry and placed a heat generating block inside the inverter. I have applied a heat load of 1.5 kW to the block. For cooling, I have added 3 fans and defined the CFM on each.
After the simulation, the temperatures are reaching 210 degrees Celsius, where in reality, it should be 55 - 60 degrees Celsius.
Also, I have noticed that the air is not flowing through the heat generating block which is the reason for the high temperatures
Please refer to the image let me know what I can do to resolve these issues
0 REPLIES 0
Technology Administrators
