Footprint in library differs from footprint in pcb document.. Ideas?
japmaco
japmaco
I have made many footprints and devices with 3d packages for this project. They all work fine exept 2....
How matter how i draw them, i still need that tight holes due to pin layout it  just smeers it out when i go to pcb view and gonna place the footprints on pcb... See pics from the actual footprint i made (super slim just to try it out, have also updated the libs so the latest rev is used by the pcb doc)
It looks like its scaled up... Its the same grid settings.
So as per now i cant place them on my pcb until i have a solution for this.
The footprints are for 2 pushbuttons from NKK with led. Links to pdfs
https://www.mouser.se/datasheet/2/295/ybnonilluminated-1663591.pdf
https://www.mouser.se/datasheet/2/295/hbilluminated-1663291.pdf
Also attatched pics on the footprints. yb_led_footprint.jpghb_led_footprint.jpgtiny footprint but still it smeers out and cant be used on pcb doctiny footprint but still it smeers out and cant be used on pcb docthis is how it looks when im gonna place them, and thats impossible at the moment.this is how it looks when im gonna place them, and thats impossible at the moment.
jorge_garcia
Hi @japmaco,
I hope you're doing well. You are getting bit by the annular ring settings in Electronics. It used to be called Restring. This blog is very detailed and explains what's going on.
https://www.autodesk.com/products/eagle/blog/what-you-didnt-know-about-eagle-restring/
Are you sure you want your pads that thin? I don't know if a board house can really produce this or if the connection will be reliable.
The key here is to setup your DRC so that your settings in the library are larger than what the DRC calculates.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
japmaco
Thanks, where is those settings in Fusion 360?
jorge_garcia
Hi japmaco,
I hope you're doing well. Those settings are in the DRC. You'll find that in the validate menu. You can also access it by typing DRC in the Electronics command line.
Best Regards,
Jorge Garcia
japmaco
thx! worked.
Is there any good discord for pcb designers?
Type a product name
