I have created a Hierarchical Design for a schematic.
According to the resources for achieving Hierarchical Design the only way is to use Modules and Ports.
So the issue is when We switch from Schematic to PCB Design , the Component name is mentioned as <MODULENAME>:<DESIGNATOR> , I want my Components to only have Designators. Is there way to do this?
Solved by jorge_garcia. Go to Solution.
Hello @deepak_elango,
Thank you for coming onto the forums. It's not possible currently to only have Designators. The best you can do for now is to assign the modules 1 letter prefixes. So let's say you have a module called POWER, you can set it's prefix to be P. So the component name would now become P1:R1 for example, which is much better than POWER1:R1.
That's the best possible for now.
Let me know if there's anything else I can do for you.
Best Regards,
