I'm trying to import DXF with logo. I've checked DXF with AutoCAD and it contains outline of the logo.
It is a shame for F3E that does not have DXF import built in.
BMP and converting it to bunch of lines is out of business.
Solved by jorge_garcia. Go to Solution.
Hi @silvio3105 ,
You have been busy this week, one thing I can recommend is to export the DXF with splines converted to polylines, then the DXF import will work. Another option is to open the DXF in Fusion 360 and then use the spline to polylines Utility to re-export it in a format that the ulp can handle.
This is definitely something that will get better since Autodesk is the home of DXF so as we continue to tighten the ECAD-MCAD integration this will be addressed.
Let me know if there's anything else I can do for you.
Best Regards,
