Here is what I have found that seems odd and I want clarity that my approach is ok below for overlapping polygon pours to the same net showing DRC error as if they are not connected and showing a single rats-next as if unconnected line.
- Create two polygon pours that overlap on one or more edges
- Both pours specify signal name of GND or some other unique NET name such as in a 2nd case of this where VOUT is the signal name on 2 other pours.
- Have one pour specify use of Thermals and the other pour without Thermals. This allows surface mount parts on the without thermals pour to connect to that pour
The specific case I use has the pour with thermals under a BGA and the connecting pours without thermals that overlap away from the BGA to allow SMT parts to connect.
I end up with a single DRC fault and unconnected airwire between these two pours unless I manually add a single trace connecting one pin of a part on each pour to a pin of a part on the other pour.
Is this expected? Before I solved this I had made test boards where the pours overlap properly so there really is a 'connection' between the pours but the software thinks there is no connections.
Thank you for your time, Mark Johnston
