I have made Gerbers & ODB ++.
I checked the Gerber, and it has the dimensions in it showing up on copper layer.
is this normal? will they show up in fabrication ?
thaks,
leo
Solved by jorge_garcia. Go to Solution.
Hi @Anonymous ,
This is not normal, check your design in Fusion 360. You likely drew the dimensions on the copper layer by accident. Inside of Fusion 360, select the dimensions and then in the inspector change the layer to be something like the measures layer or another layer that is not being used for anything else.
Best Regards,
Thanks @jorge_garcia that is exactly what i did!
I assumed that dimensions would be an attribute or something and wouldn't show up, insted anything i put in the copper layer will show up in copper layer, thanks!
