Message 1 of 9
Hi!
I have a strange problem, one of the components i use has 6 GND and multiples of power supplies of same voltage. They do not need to all be connected, just one of each or a couple should be sufficient. In my schema i connected only one, but on the PCB it shows they are all connected to each other. How can I remove these connections?
In the attached image you can see pin 39 GND is connected to 34 GND, but in the schema this connection does not exist. I guess this could be a feature of the component, but i have not find a way to edit that.
Best Regards,
Marcus
Marcus
