Creating a Pick and Place CSV file
erica7BQKN
erica7BQKN
Hi, I'm struggling to create a pick and place CSV file within fusion 360.
I've tried the automatic pick and place under 'manufacture' but this only saved as an mnt file.  I also tried to run ULP under 'automation' and create a centroid file however I had issues saving this.
Is there any other way I can save a pick and place CSV file?
Thanks in advance!
RichardHammerl
Hi @erica7BQKN
the CAM Processor can create Pick&Place data for you.  IN the Assembly section you find pick&place. It can be exported as CSV.
Hope this helps.
Best regards,
Richard Hammerl
erica7BQKN
Great, thanks @RichardHammerl this worked perfectly, thank you so much for your help!
Is there any way to obtain both front and back pick and place files into one file?
Thanks again,
Erica
