i'm working with a BGA device with 19x17 pads. I want to connect the net of a via to the net of each pad for later routing. Right now I manually change the net name of the via to the net name of the pad which is quite tedious. In Eagle i could simply place the via directly on the pad and it was connect with the right net. What is the most efficient way for this task in Fusion 360?
Thanks in advance!
