Component Array... cannot set up on the angles I need
edneeves
edneeves
I am slowly getting my head around Fusion 360 for Electronics. I am building a stepped attenuator and need help to understand how I can realign my array with the gap at the top (eg 45 degrees from 12 o'clock finishing a 315 degrees). Seem like Fusion treats the starting point as 3 o'clock and no matter how I play around with it, I cannot get the gap pointing up. There was a thread on here but the question was removed.
And yes the segments are not the right shape. I haven't figured out how to make them wider at the top yet.
edneeves
I managed to find a solution in the end. Instead of trying to place 36 components for 270 degrees, I placed 48 on 360 and then manually deleted the ones I didn't need. Then updated the schematic to link to the correct ones based on the placement in the 2D model.
