add shortcut for layer dialog(L key) and make beter dialog(not dropdown).
Group by layer type - eg., Copper layers into one group, silkscreen layer into another, keepout layer into third group.
It's easier to see all layers divided into gropus rather than scrolling through dropdown.
Solved by jorge_garcia. Go to Solution.
Hello @silvio3105,
I hope you're doing well. You can setup the shortcut already if you wish with Shortcuts dialog or using Fusion's built in shortcut system.
In the regards to groups, have you considered using layer sets? You could probably achieve something similar.
Hello @silvio3105,
I hope this message finds you well. I'll report this as an enhancement request
Best Regards,
