Where is selection filter tab?
rbkyorem
rbkyorem
Where is selection filter tab in Fusion 360 electronics?
constantin.popescuXD3CL
Hey,
See picture (Selection.Filter.PNG) below, the Selection Filter is part of the Inspector panel. In my Fusion360 I have it docked on the right side of the workspace. Maybe you clicked on the "fast forward >>" arrows on the Top-Right corner and made the entire Inspector panel collapse (see the 2nd picture - Inspector.Panel.Collapsed.PNG).
I hope this helps.
Kind Regards,
Constantin Popescu,
Constantin Popescu
Principal Software Engineer
rbkyorem
I can't see it. Used to right click on panel and select visibility on Eagle. I don't know how to do that on Fusion 360.
rbkyorem
It seems so, unknowingly I seem to pressed CTRL + ALT + F and it makes the selection filter disappear. Probably I was trying to enter full screen mode not know which keys to press. Anyway there should be a toggle somewhere by mouse and if anyone knows please share how :).
Pieter.Jan.Van.de.Maele
As you mention ctrl+alt+F is the keyboard shortcut toggle. If you want to toggle this from the UI please use the "views" option:
Hopefully this helps!
Pieter-Jan Van de Maele
Senior Engineering Manager, Fusion Electronics
