Using library.io
Learning to use Fusion 360 with my PCB designs. Two days in and its going pretty well but I wonder if I'm missing something obvious. For example Library.io seems so comprehensive yet I can't find a standard 3mm red LED in the library, which surely has to be one of the more common components. Either it doesn't exist or I'm not using the best search criteria.
I ended up modifying and using an stl file from Kingbright, which was easy enough and got the job done. But I'm left with the nagging feeling that I've missed something obvious in my learning process.
