User Library-SMD CAPACITOR could not be uploaded because access to the "PCB projects"project was denied. Please contact the project moderator for assistance.
mark4GG4A
Message 1 of 9
mark4GG4A
I can not find the source of this error message that keeps coming up. I have looked everywhere and can not find a library called SMD-CAPACITOR anywhere or anylibrary . Does anyone know how and where to find this error so I can get rid of it...its really annoying it keeps coming up literally every minute or so
Replies (8)
Message 2 of 9
yqliu
This error usually happens when you are saving a document which is owned by others but the access permission was removed. Based on your description, this is not your case.
Can you share your Applog file to me?
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
Message 3 of 9
mark4GG4A
These are the log files in the Aoplications log
Message 4 of 9
mark4GG4A
There are 18 log files...I cant see all of them there for some reason
Oh can only load 3 files...also I am not on the usual computer I use. I will do this again when I get back to work on monday. These log files may not contain the correct information
Message 5 of 9
yqliu
You are right. The log files here contain no information related to the error.
Message 6 of 9
mark4GG4A
This is from the work computer. There are only 2 of the application log files here
Message 7 of 9
yqliu
The problem is because uploading a STEP file failed. You can search "ced78437-0065-4d34-a772-2157a3b01ae9.STEP" in your Fusion 360 installation folder (/Users/Work/Library/Application Support/Autodesk/Autodesk Fusion 360/) and check which library/part is using this STEP file.
Message 8 of 9
mark4GG4A
I found the files and deleted them but the problem seems to still be persisting
Message 9 of 9
mark4GG4A
Do I just delete the files or is there a special way to unistall them
